M miracle happen Commendable Mar 27, 2016 3 0 1,510 Jan 2, 2017 #1 can I put this on my cpu? Dow Corning 3145 RTV http://www.dowcorning.com/applications/search/default.aspx?R=146EN
Solution gussrtk Jan 2, 2017 I wouldnt. why would you put that on your cpu? the paste transfers the heat from CPU to the CPU COOLER heatsink unit. This is just gonna cook your CPU
gussrtk Splendid Dec 14, 2012 1,535 3 21,615 Jan 2, 2017 Solution #2 I wouldnt. why would you put that on your cpu? the paste transfers the heat from CPU to the CPU COOLER heatsink unit. This is just gonna cook your CPU Upvote 0 Downvote Solution
g-unit1111 Titan Moderator Jul 27, 2011 42,880 888 104,940 Jan 2, 2017 #3 No, that is not thermal compound. Upvote 0 Downvote
Johnathan127 Honorable Mar 28, 2015 163 0 10,710 Jan 2, 2017 #4 An example of thermal paste: http://www.newegg.com/Product/Product.aspx?Item=9SIA2W04RT0404&cm_re=thermal_compound-_-35-186-038-_-Product Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,700 22,191 184,590 Jan 2, 2017 #5 No. That is an adhesive...a type of glue. I used to use similar on various applications on aircraft. Not thermal paste. Just like you wouldn't use thermal paste for hand cleaner. Or super glue for eyeliner. Right stuff for the right purpose. Upvote 0 Downvote
