Is it worth getting a heat-sink/CPU fan instead of stock??
Xtal_
193
I am purchasing the AMD FX6300 (comes with stock fan) and i have heard rumors that this stock fan over heats your PC, is this true? I am not a hardcore gamer or anything but here are the other specs:
8gb RAM
1tb storage
amd r9 270x
The stock HSF should already have paste pre-applied, hence the importance of installing it properly on the first try - once the original application has been ruined by a botched install, you have to scrape it off and start clean with aftermarket paste.
A couple of weeks after purchasing i should have 3 fans (1 back, 2 front) will this be ok?
I will need to apply thermal paste right?
