Is it worth it ATI RADEON HD7570 4GB GDDR5 128BIT
Kc779
20
Koyo ATI RADEON HD7570 4GB GDDR5 128BIT is it worth the money? Because it's kinda cheap for a 4gb video card
There are a lot of low-end 4 GB cards. That's not an expression of a GPU's power.
Hard to say if it's worth the money when you don't list the money. If I was going to buy this at all, I wouldn't pay more than $25.
It's around 45$ us when I convert it from our currency
If you can get the Nvidia GT 1030 (2GB) for $69.99, then that represents better value for money (bang for buck).
https://www.newegg.com/Product/Product.aspx?Item=N82E16814500424&nm_mc=AFC-C8Junction-Components&cm_mmc=AFC-C8Junction-Components-_-Video%20Card%20-%20Nvidia-_-ZOTAC-_-14500424&cm_sp=&AID=11892368&PID=3962334&SID=
There is zero point in having 4GB of vram for gaming on a card that weak.
I only have around 45$-50$ of budget, what can you recommend?
You need *enough* VRAM, but outside of that, it doesn't determine the power of the GPU. This is an extremely low-end GPU whether it has 1 GB, 2 GB, 4 GB - it could have 16 GB of VRAM and it wouldn't mean anything.
What can you recommend for around 45$-50$ video card?
You're going to have to look at the used markets in your country. If you're trying to run games, you'd need a significantly larger budget to buy new. If you just want to surf the web, I'd check and see if your integrated graphics, if you have them, are functional enough for your needs.
I'll just earn more money until I can buy a better video card for gaming, thanks for the tip sir
Today I only have the Nvidia GT 730 2gb video card can I still play with this video card?
You can do some light gaming without. Games like GTA V, Battlefield 1, etc. would be a challenge to make playable. You actually wouldn't see a gain moving to a 7570 if you have a 730. If your'e on a budget, I'd target an RX 560 as a goal for a nice budget gaming card.
Thank you so much dude I'll be earning much more money to buy a video card for playing GTA 5
