[SOLVED] Is it worth to upgrade from 27 inch 2560X1440 monitor to 29 inch 2560X1080 monitor
Oct 2, 2018
Is it worth to upgrade from 27 inch 2560X1440 monitor to 29 inch 2560X1080 Ultra wide monitor. I use the monitor for normal works such as productivity, YouTube, movies and very less gaming. I am getting the ultra wide monitor a 100 bucks cheaper than the 27 inch one. I am in a dilemma and wanted so opinions to help me :)
daerohn
105
15
if you are in to 3D modelling, content creation and such try buying a second monitor. especially if you have to run two programs simultanously.
In my opinion it is not worth the "upgrade" to the 2560X1080 resolution monitor. For productivity I like a taller monitor so the ultrawide would be out. I have a dell U2715h which is a 2k(2560X1440) 27" monitor. I just love that size of monitor and resolution.
