GhislainG is absolutely correct; it's not a question of
if your pump will fail, it's instead a question of
when. Many users forget that moving parts eventually fail.
Electric motors have bearings, so anything driven by an electric motor such as cooling pumps, fans and hard drives
will fail. Unlike custom loops which use high-end pumps, AIO pumps are of inferior quality. Computers which run 24/7 are prone to premature pump failure. Cooling pumps have an impeller to circulate water. Impellers can seize from blockages caused by sediment due to galvanic corrosion (dissimilar metals; aluminum / copper), which is a common problem in AIO units, whereas custom loops are all copper. AIO's will also fail due to hose permeability which causes very gradual evaporation over time, whereas custom loops have a reservoir so coolant can occasionally be topped off.
The moral of the story is; power down your rig when it's not in use.
EDIT: You
might get away with using the Noctua NH-D15 big-air cooler
IF you purchase a delidded 7820X from
Silicon Lottery -
https://siliconlottery.com/collections/skylake-x/intel-i7-7820x
Silicon Lottery is a company that sells professionally delidded CPU's so inexperienced users don't have to risk doing it themselves. Delidding reduces Core temperatures up to 25°C. Delidded CPU's from SL cost a bit more, but SL warranties their work, does a great job and you'll know what you're getting.
I've been running delidded processors on my builds and personal rigs since 3rd Generation 3770K Ivy Bridge, when this temperature mess really heated up. That's when Intel switched from using Indium Solder between the Die and the Integrated Heat Spreader (IHS) to a Dow Corning Thermal Interface Material (TIM). I highly recommend delidding because, it's by far, the most effective method of reducing Core temperatures.
Read
Section 9 - The TIM Problem:
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
CT
