Is liquid cooling system safe for OC ? should I just stick to old fashion fan system?
Given you have the right components for liquid cooling you'll have way better result than air cooling and especially in overclocking. My advice don't go cheap with liquid cooling. My first liquid cooling kit was a cheap one and it only worked just slightly better than my air coolers.
So what components are you planning to cool and how much overclocking are you looking at?
Yes it is safe, I've had problems with extreme cool temps, water freezing pump submerged in the water. If you plan on trying you must insulate ever bit of the hose and CPU. Condensation will set in when the temps in the case reach around 20c. I built a water fountain chiller awhile ago and I was fine all winter and spring but when the hot summer came I had the worst case of condensation. Dielectric grease saved my system from sure death.
