A Aditya_17 Reputable Jan 25, 2016 3 0 4,510 Jun 10, 2016 #1 I am going to take electronics engineering. I do some coding, web designing. I have many h.265 full HD videos. Will it be able to run them? Also, can it run CS go and Minecraft?
Solution rgd1101 Jun 10, 2016 check the software requirement on the software if going to use to see if it support PC or Apple OS
rgd1101 Don't Moderator Nov 7, 2011 74,864 4,245 176,290 Jun 10, 2016 Solution #2 check the software requirement on the software if going to use to see if it support PC or Apple OS Upvote 0 Downvote Solution
