Is MX-4 a conductive thermal paste or not?
TheRealArchi
75
As the title says, I want to know about the conductivity of this thermal paste because I want to know if putting a little bit more of it on the CPU will cause any damage or not.
I heard that if the thermal paste is not conductive, it wont do anything if you put more quantity than usual.
So is the MX-4 or not ?
Thermal paste or TIM should be applied sparingly to fill just the tiniest of voids.
TIM can range from 1.5 to 9.0 w/mk (watts per meter kelvin) and the higher the better for thermal conductivity.
Arctic MX4 is an excellent TIM at 8.5 W/(mK)
If you apply too much TIM you have the chance of it squeezing out the sides and that you DO NOT want.
BTW; Do not get confused between thermal and electrical conductivity.
all pastes are thermally conductive. Thats ... kind of the point.
He's asking if its ELECTRICALLY conductive, which is a serious issue, as it can short parts on the PCB if it spills over.
