Is my pc build compatible? Or is my component defected? I've been watching youtube tutorials and reviews on what the best parts are for a gaming pc and I came up with this: https://pcpartpicker.com/list/7w94Yr .These are all the parts I'm using for my build except for the memory ram which I use the Timetec (P/N 75TT133U2R8-8G) 8GB Dual Rank 1333MHz DDR3 . Basically, I've put together all the parts into the right places with countless replays and tests but the problem I get is that my monitor still says no signal. All the fans work except the gpu fan moves and stops (which is weird) but other than that, I connected the psu to the gpu and even tried to connect the motherboards vga directly to the monitor but still it says no signal. I also tried to connect the vga converter to dvi to the gpu and still says no signal. Also my monitor doesn't have an hdmi port and my motherboard doesn't have a speaker.
