Is my build compatible or defective? No signal on monitor
Jamesooo6425
Commendable
Dec 11, 2016
Is my pc build compatible? Or is my component defective? So I've been watching youtube tutorials and reviews on what the best parts are for a gaming pc and I came up with this: https://pcpartpicker.com/list/7w94Yr .These are all the parts I'm using for my build except for the memory ram which I use the Timetec (P/N 75TT133U2R8-8G) 8GB Dual Rank 1333MHz DDR3 . Basically, I've put together all the parts into the right places with countless replays and tests but the problem I get is that my monitor still says no signal. All the fans work except the gpu fan moves and stops (which is weird) but other than that, I connected the psu to the gpu and even tried to connect the motherboards vga directly to the monitor but still it says no signal. I also tried to connect the vga converter to dvi to the gpu and still says no signal. Also my monitor doesn't have an hdmi port and the I don't have a speaker to go along with the motherboard
Without an APU processor there would be no video from MB itself so you can skip that check. Take everything out of the case and and assemble it part by part on a table. Connect a speaker o to MB so you can hear POST beeps, that should tell you what may be wrong.
