Hi Folks,
I am in the process of selecting the best package for my workstation specs, and I think I have come up with a good solution, but I would like your opinions/advice about if these specs are fit for purpose.
And my purpose for this workstation is editing DSLR footage using Adobe Premiere Pro/ After Effects, using green screen and some 3D effects for short documentaries and tutorials on Vimeo and Youtube, by way of a hobby.
I am very creative, but I am not blessed on the technical side of things, but after much research over many months I wonder if this is the best I can do with the budget of £3000 I have for a PC. Here's the specs on the build:
Intel 4th Generation Core i7 (4790K) 4GHz Quad Core Processor 8MB L3 Cache (Boxed)
2x HyperX Savage 16GB (2 x 8GB) Memory Kit 2133MHz DDR3 CL11 DIMM
Asus Z97-P Motherboard 5th/4th Gen Core i7/i5/i3/Pentium/Celeron 1150 Z97 ATX RAID Gigabit LAN (Integrated Intel HD Graphics)
Corsair Hydro Series H100i Extreme Performance CPU Cooler
Samsung 850 EVO MZ-75E250B (250GB) Solid State Drive SATA 6Gb/s 2.5 inch (Internal) Basic
Western Digital Black 4TB (7200rpm) SATA 6Gb/s 64MB 3.5 inch Hard Drive (Internal)
PNY Quadro K4200 4GB Professional Graphics Card
Samsung SH-224DB DVD Writer Optical Drive
Cooler Master Silencio 452 Silent Mini-ITX, Micro ATX, ATX Mid Tower Case USB 3.0 with SD Card Reader
Corsair RM650 RM Series 650 Watt Fully Modular Power Supply Unit (80 PLUS Gold Certified)
ASUS PCE-N15 300Mbps PCI-E Wireless card,
Microsoft Windows 7 Ultimate 64-bit (SP1)
Feedback on what you think would be hugely appreciated, as I am nervous I have made the best choices above.
