Is my build going to work?
brownayy
26
Hey there, I'm currently deciding on which parts to buy for my new gaming pc. I have got a list of components that I would like and I'm unsure if it will all be compatible.
CPU - AMD Phenom II X4 955
Motherboard - ASRock M3A UCC
http://www.ebuyer.com/231368-asrock-m3a-ucc-amd-480x-socket-am3-6-channel-audio-atx-motherboard-m3a-ucc
Video Card - Gigabyte GeForce GTX 550 Ti 1GB
I already own compatible memory, hard drives, disk drives, sata cables and a case so I do not need to buy anything else.
I have purchased a 750w PSU with the correct connectors for the graphics card.
I hope you can help me out!
- Sam
it is compatible .however the motherboard isn't that good but it depends on your budget which you haven't listed . since you got a 750 w psu you might as well sli the same card when you get the money but you will need a diffrent mobo for that
