Is my build good and are there going to be any technical problems? Could somebody help me with this?
game-source
219
Hi, this is my first build and I'm worried, are there going to be any technical problems with it.
I have already bought the CPU and GPU but the other components, not yet.
My components are :
CPU : Intel core i5-4670k
GPU : pny gtx 770 4gb
MB : Gigabyte z87 m hd3
HDD : WD 1TB SATAIII Caviar Red 7200rpm 64MB
RAM : 1x8GB Vengeance DDR3 1600Mhz 1.5V
Case : RAIDMAX SUPER ALTAS ATX-295W Middle Tower
Optical drive : LG GH24NSB0
Power supply : CORSAIR Builder Series CX 750 Watt CP-9020015-EU
Thanks
It it only has 2 slots, then it is OK to have 1 stick of 8 gb. It is impossible to get 12 gb, you can get 16 gb with 2 sticks of 8 gb.
Is there a difference between 1 or 2 sticks of ram, i mean the motherboardhas only two slots and i wanted to upgrade it later to 12 gb or the 8gb works fine? I could replace the HDD with the WD black.
Will the WD black do fine? Instead of the red one.
WD Black is their enthusiast hard drive, perfect for gamers and renderers.
