I have a corsair 500r. i have 2 front 120mm intake fans and a rear 120mm exhaust fan... Ive taken of the side 200mm intake as the side grill has no dust filter and the fan speed controller on the case is only a 3-way controller and the rear 120 is really loud if i dont use a fan controller.
Im buying a GTX 660 TI,
I have my eye on a Asus GTX 660 Ti Direct CUII OC
but it exhausts hot air inside the case. Will that heat up the ambient temperature inside the case? (which ultimately means increasing fan speeds to control temp. = Loud )
If that happens ill have to buy an EVGA GTX 660 Ti FTW Signature 2
This has a closed shroud cooler which exhausts air out the back of the case but still has 2 fans.
Even if im okay with the Asus card, Will the EVGA be better? That'll solve all the problems
Unfortunately there are not many reviews on the EVGA card yet 🙁
Which card would you choose for my needs?(quiet, cool and good customer support all over the world as i live in india)
Thanks everyone in advance 😀
