So I've been having freezing issues lately, and it appears to be temperature related. Mainly with the RAM, since when I set up a specific fan for it, the problem is less common. However, I'm not entirely sure if my unorthodox setup is the best configuration.
As pictured, I have an intake fan on top, but it's divided internally by a plastic spacer that I wedged inbetween the two fans. Is there any way I could reconfigure this setup to provide better cooling, or am I decent as is?
CPU: i5-6600 Skylake
RAM: 16GB 2400MHz DDR4
Mobo: MSi Z-170A Krait
GPU: 2x Crossfire R9 280 3GB
240GB SSD and 1TB WD Hard Drive configuration
850W Thermaltake Grand
CPU temps are 28C when idle, 40C under load
GPU 1 temps are 40C when idle, 75C under load
GPU 2 temps are 28C when idle, 60C under load
UPDATE: RAM temperatures during a crash read as 40 degrees C
Motherboard read 40 degrees C as well throughout the whole board.
