I believe my brand new workstation chassis could be causing a wireless signal interference. Just installed an Asus PCE-N15 adapter. Running on 2.4 GHz. 5 GHz is also available and only taxed by 1 other device.
System:
Processor: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz, 3501 Mhz, 4 Core(s)
Video Card: AMD FirePro V4900 (FireGL V)
Power Supply: Samsung SSD 840 EVO 250G SCSI Disk Device
Chassis: Corsair 200R
Test #1: Chassis is right beside wireless router
80 Mbps download, 15 Mbps upload
Test #2: Chassis is at same elevation as router, antennas pointing in same direction as router, but going through 1 wall, 30 ft away from router
40 Mbps download, 10 Mbps upload
Test #3: Rotate chassis 180° so antennas are facing the wall (chassis is now in between antennas and router). Same elevation, same distance as above test
18 Mbps download, 10 Mbps upload
Test #4: Rotated chassis, same as test #3, but lowered chassis to the ground level (4' drop)
0-10 Mbps download, 0-8 Mbps upload
Would occasionally time-out rogers speed test
Consistently close to 0 Mbps during peak hours, failing to connect or taking forever to connect to internet pages
Test #5: My laptop, in the same positions as the tower achieves much higher download speeds on the 2.4 GHz network and double the speeds on the 5GHz.
Are these tests not indicating that the chassis itself is blocking the wireless signal to the rear-facing wireless adapter? Is this normal for workstations with towers? Could any high voltage internal devices (ps) be causing this? What might be the effect of swapping the adapter for a different adapter that runs on 5 GHz? Why are download speeds only affected?
Already tried ASUS drivers and preferred RealTek drivers. Can post pictures if necessary.
Any help would be appreciated. I really don't want to run an ethernet cable or move this machine to the other room.
Thanks in advance!
Justin
System:
Thanks in advance!
Justin
