is my choice of parts ok.
Suraj Grewal
16
I wanna buy 4770k cpu with 760 tf 2gb graphics card 8gb ram,
how much power will I need?
is antec-900 watts ok
is cpu fast enough to not bottleneck the card?
is deep cool neptwin cooler ok?
what else will I need to make it better?
Whoa, 900W? There's an XFX 550W at Newegg that will do just fine. If you want to do SLI get a Corsair TX750. Either way you don't need 900W, no worries.
Yes the CPU is fast enough. You could in fact save $100 by getting an i5-4670k instead.
The config should work just fine without any issues the power is more than enough to maintain and regarding the cooler there are better ones but im sure even if you got the ones i have in mind it would be of negligible difference in terms of performance so that should be fine as well. just make sure your mother board can support your gear
What else you will need... A motherboard. Z77 boards would work well with i5-4670k or i7-4770k, and they're good if you want SLI too (i.e. if you want to add a second GTX 760 later). Of course, in that case make sure you get a MB with two PCI-E x16 slots.
E.g.
MSI Z87-G45 Gaming LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Pro Gaming with Killer Networking & Sound Blaster Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130693
