Is my cooler enough for overclocking ?
Takeda
6
my motherboard is : Gigabyte GA-B85-HD3 Retail ,and i have cpu cooler nzxt respire T40 ,my question is if thats enough cooling for extreme overclocking?
Not 100% correct.
Air cooling is just as efficient, it just depends on the cooler you get.
Your motherboard is not an Overclocking motherboard, you'd need a Z97 motherboard.
Overclocking also depends on your CPU, what CPU do you have?
Depending on what CPU you have it can depend on the overclock, but with an air cooler like that, most people could probably get around 4.4GHz~ depending on...
For overclocking performance, a water-cooler is the most efficient. The cooler you have should work fine for light overclocking. Don't go too extreme. Best way to tell is my monitoring temps closely and running some stress tests. But overall, Water-Coolers are highly recommended, but yours should be able to do some light overclocks.
thanks for ur answer,uhmm can u link me a liquid cooler which should make extreme overclocking without worry ,thu isn't complicated to replace a new cpu cooler?
Not 100% correct.
Depending on what CPU you have it can depend on the overclock, but with an air cooler like that, most people could probably get around 4.4GHz~ depending on your luck with silicon.
OP - Don't waste your money on an AIO cooler if it isn't needed, there's fans that perform on par with most 240mm AIO coolers (Noctua NH-D15)
