Is my cpu better HELP PLEASE
ItsWeiz
89
ok soo i want to play black ops 3 on the pc i meet most of the Minimum requirements to play but my cpu is the only thing that it does not meet its a the amd a4 7300 apu i got a gpu now the gtx 750 1gb black ops 3 Minimum cpu requirements is the AMD Phenom II X4 810 @ 2.60 GHz i want to khow that if i put the
AMD Athlon X4 860K 3.7GHz Quad-Core Processor cpu to replace my apu would it be better or same as the AMD Phenom II X4 810 @ 2.60 GHz r=thanks
Your A4 7300 is actually better than the Phenom II X4 810 on per core performance, but I haven't got a clue how well multi-threaded BO3 is going to be as I don't follow any CoD games and how many threads at a minimum BO3 will need to run.
The 860k or a 7850k would be better than either the Phenom II or your A4 7300.
i would but my motherboard only supports amd
ok thank you soo much i think ama go for the 860k since its more bettter and cheaper
Then get a new board.
