Is my CPU overheating? And if so, how to fix it?
Skyleft
Commendable
Feb 13, 2017
16
Hello. I recently got a new computer, only to realize that I couldn't livestream as well as I used to with my last one.
The video quality is very bad, so I figured it could be because my CPU was overheating.
I used a program to measure the CPU's temperature and got these results: http://prntscr.com/e8iox0
I don't know much about it so maybe you guys could tell me if it's bad or not.
And if it is, how could I fix it? It is a new PC.
Like Dustybin said, that's clearly a result of the cpu cooler not cooling the cpu. It might not be attached properly, possibly coming loose during transport, and if that's the case, you will want to replace the thermal compound when you re-attach it. It could also be that the fan on the cooler isn't working properly though, so you might check that it's spinning properly and not blocked by stray wires or anything.
Did you buy this PC assembled or make it yourself? If you built it yourself you should take your CPU cooler off, clean away the thermal paste and reapply as a start. Failing that if you're using a stock cooler you should replace it with a quality after market cooler.
If you bought this built then contact whoever made it and get them to fix it, those temps are way too high.
The other thing to consider is air flow around and inside the computer, do you have any case fans and what is your cable management inside? If you've got the PC in a built in unit it needs clearance around it especially where fans are venting hot air.
It is actually quite relieving to know that the temperature is a problem since it would explain all the issues I've been having.
I did buy all the different parts myself, but the shop built the actual PC. I am unable to contact them as I moved out very far away, and I picked the parts pretty much following a guide as I am not used to messing with this kind of stuff.
I can definitely try what you've said but I would need a more in depth explanation to not [censored] anything up. It would be great if you could either explain the steps I should take or link me a guide that would explain how to do what you've suggested.
This is what I got for my current pc:
System Information report written at: 02/14/17 09:55:48
System Name: DESKTOP-004GJ91
[System Summary]
Item Value
OS Name Microsoft Windows 10 Enterprise
Version 10.0.14393 Build 14393
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-004GJ91
System Manufacturer Gigabyte Technology Co., Ltd.
System Model H110M-S2H
System Type x64-based PC
System SKU Default string
Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. F20a, 26-Oct-16
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.14393.206"
User Name DESKTOP-004GJ91\Adrià
Time Zone Romance Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 12.6 GB
Total Virtual Memory 18.3 GB
Available Virtual Memory 14.6 GB
Page File Space 2.38 GB
Page File C:\pagefile.sys
Device Guard Virtualization based security Not enabled
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
[Hardware Resources]
[Conflicts/Sharing]
Resource Device
I/O Port 0x000003C0-0x000003DF PCI-to-PCI Bridge
I/O Port 0x000003C0-0x000003DF NVIDIA GeForce GTX 1060 6GB
I/O Port 0x00000070-0x00000070 Motherboard resources
I/O Port 0x00000070-0x00000070 System CMOS/real time clock
IRQ 11 Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123
IRQ 11 Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
Memory Address 0xE2100000-0xE21FFFFF PCI-to-PCI Bridge
Memory Address 0xE2100000-0xE21FFFFF Realtek PCIe GBE Family Controller
I/O Port 0x0000E000-0x0000EFFF PCI-to-PCI Bridge
I/O Port 0x0000E000-0x0000EFFF NVIDIA GeForce GTX 1060 6GB
Memory Address 0xEF200000-0xEF2FFFFF PCI-to-PCI Bridge
Memory Address 0xEF200000-0xEF2FFFFF Realtek PCIe GBE Family Controller
Memory Address 0xFD000000-0xFDABFFFF Motherboard resources
Memory Address 0xFD000000-0xFDABFFFF PCI Express Root Complex
Memory Address 0xFF000000-0xFFFFFFFF Motherboard resources
Memory Address 0xFF000000-0xFFFFFFFF Legacy device
IRQ 16 High Definition Audio Controller
IRQ 16 Realtek PCIe GBE Family Controller
IRQ 16 NVIDIA GeForce GTX 1060 6GB
Memory Address 0xD0000000-0xE1FFFFFF PCI-to-PCI Bridge
Memory Address 0xD0000000-0xE1FFFFFF NVIDIA GeForce GTX 1060 6GB
Memory Address 0xA0000-0xBFFFF PCI Express Root Complex
Memory Address 0xA0000-0xBFFFF PCI-to-PCI Bridge
Memory Address 0xA0000-0xBFFFF NVIDIA GeForce GTX 1060 6GB
Memory Address 0xEF100000-0xEF1FFFFF PCI-to-PCI Bridge
Memory Address 0xEF100000-0xEF1FFFFF SB Recon3D PCIe Audio Controller
I/O Port 0x000003B0-0x000003BB PCI-to-PCI Bridge
I/O Port 0x000003B0-0x000003BB NVIDIA GeForce GTX 1060 6GB
Memory Address 0xEE000000-0xEF0FFFFF PCI-to-PCI Bridge
Memory Address 0xEE000000-0xEF0FFFFF NVIDIA GeForce GTX 1060 6GB
I/O Port 0x0000D000-0x0000DFFF PCI-to-PCI Bridge
I/O Port 0x0000D000-0x0000DFFF Realtek PCIe GBE Family Controller
I/O Port 0x0000FFFF-0x0000FFFF Motherboard resources
[DMA]
Resource Device Status
[Forced Hardware]
Device PNP Device ID
[I/O]
0x0000F050-0x0000F057 Standard SATA AHCI Controller OK
0x0000F040-0x0000F043 Standard SATA AHCI Controller OK
0x0000F020-0x0000F03F Standard SATA AHCI Controller OK
0x00000A00-0x00000A2F Motherboard resources OK
0x00000A30-0x00000A3F Motherboard resources OK
0x00000A40-0x00000A4F Motherboard resources OK
0x0000002E-0x0000002F Motherboard resources OK
0x0000004E-0x0000004F Motherboard resources OK
0x00000061-0x00000061 Motherboard resources OK
0x00000063-0x00000063 Motherboard resources OK
0x00000065-0x00000065 Motherboard resources OK
0x00000067-0x00000067 Motherboard resources OK
0x00000070-0x00000070 Motherboard resources OK
0x00000070-0x00000070 System CMOS/real time clock OK
0x00000080-0x00000080 Motherboard resources OK
0x00000092-0x00000092 Motherboard resources OK
0x000000B2-0x000000B3 Motherboard resources OK
0x00000680-0x0000069F Motherboard resources OK
0x0000FFFF-0x0000FFFF Motherboard resources OK
0x00001800-0x000018FE Motherboard resources OK
0x0000164E-0x0000164F Motherboard resources OK
0x00000040-0x00000043 System timer OK
0x00000050-0x00000053 System timer OK
0x0000D000-0x0000DFFF PCI-to-PCI Bridge OK
0x0000D000-0x0000DFFF Realtek PCIe GBE Family Controller OK
0x00001854-0x00001857 Motherboard resources OK
0x00000800-0x0000087F Motherboard resources OK
0x0000F000-0x0000F01F Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123 OK
0x000003F8-0x000003FF Communications Port (COM1) OK
0x00000000-0x00000CF7 PCI Express Root Complex OK
0x00000D00-0x0000FFFF PCI Express Root Complex OK
0x0000E000-0x0000EFFF PCI-to-PCI Bridge OK
0x0000E000-0x0000EFFF NVIDIA GeForce GTX 1060 6GB OK
0x000003B0-0x000003BB PCI-to-PCI Bridge OK
0x000003B0-0x000003BB NVIDIA GeForce GTX 1060 6GB OK
0x000003C0-0x000003DF PCI-to-PCI Bridge OK
0x000003C0-0x000003DF NVIDIA GeForce GTX 1060 6GB OK
0x0000FF00-0x0000FFFE Motherboard resources OK
0x00000020-0x00000021 Programmable interrupt controller OK
0x00000024-0x00000025 Programmable interrupt controller OK
0x00000028-0x00000029 Programmable interrupt controller OK
0x0000002C-0x0000002D Programmable interrupt controller OK
0x00000030-0x00000031 Programmable interrupt controller OK
0x00000034-0x00000035 Programmable interrupt controller OK
0x00000038-0x00000039 Programmable interrupt controller OK
0x0000003C-0x0000003D Programmable interrupt controller OK
0x000000A0-0x000000A1 Programmable interrupt controller OK
0x000000A4-0x000000A5 Programmable interrupt controller OK
0x000000A8-0x000000A9 Programmable interrupt controller OK
0x000000AC-0x000000AD Programmable interrupt controller OK
0x000000B0-0x000000B1 Programmable interrupt controller OK
0x000000B4-0x000000B5 Programmable interrupt controller OK
0x000000B8-0x000000B9 Programmable interrupt controller OK
0x000000BC-0x000000BD Programmable interrupt controller OK
0x000004D0-0x000004D1 Programmable interrupt controller OK
0x000000F0-0x000000F0 Numeric data processor OK
Regarding my last one, I am not sure, but it was way less expensive than this one and I had it for around 4 years. All I remember is the processor was an i5 and the price of the whole thing was 800€.
Well is really easy to do, if you follow the steps you will be just fine.
This is just one of the endless vids you can find about thermal paste and assembling CPU cooler, like Dustybin said before if this does not resolve the temps issue you will need to replace it for an aftermarket CPU cooler.
Always try to keep your temps as low as possible, this will give you the best possible performance of your chip and will last longer.
https://www.youtube.com/watch?v=r2MEAnZ3swQ
I strongly suspect the CPU cooler is badly mounted, before you remove it though make sure you have spare paste and a suitable wipe and cleaner fluid to remove the current paste. You need an alcohol based cleaner and some form of wipe that doesn't leave lint or masses of residue behind.
And of course, make sure your computer is completely powered down, and its cord is unplugged before attempting to work on the CPU. >_>
Well you have your CPU water cooling, the CPU is just beneath the pump (the round metal/plastic thing with the ANTEC logo on) there is something definitely wrong with that cooling if you are getting so hight temps.
Can you make a better picture with some natural light so we can see the whole thing a bit better?
Ok lets star with the basics, with your PC on and running carefully place your fingers on top of the pump and see if you feel the pump is working, there must be a vibration, if it is too hot to the touch and you can feel the pump, well in that case the pump may be dead (I don´t think so but we need to discard everything)
I don't feel any vibration at all, but it's definitely not very hot. About the same temperature as when I touch the PC case
It seems that next step is un mount the CPU pump, for this you need to remove the radiator and then the CPU pump, remember you will need thermal paste to replace the existing once you detach the cooler from the CPU.
No, not one bit.
Edit: Actually I am looking at it now and there is water but its barely barely noticeable
You shouldn't have done that.
If water did get onto your motherboard or graphics card, then you can't turn your pc on until water has completely dried off.
It may require days and excessive ventilation.
I I´m really concenr about that liquid liquing I see in your pic, open the other side cabinet and you should see the mounting screws that hold the base, anyhow like I said I dont like that liquid droping all over, did you open up the pump?
Your AIO cpu water cooler is not designed for disassembly.
You're gonna have serious problems refilling it and eliminating air bubbles.
Put the water-block back together. Then wiggle it around a bit so it comes off the cpu and remove it completely.
Until you figure out, how to refill your AIO water cooler and eliminate air bubbles, get air cooler for your cpu.
