Hello my cpu is about 70 degrees celsius at idle and i think that is too hot when i have heard they should be around 45 degrees celsius at idle.
I am concerned it is too hot and if it can affect it over long term of using it.
I have a ryzen 7 3800x whith the stock cooler that comes whith it. I have two 140mm fans in the front sucking air in and two 140mm and one 120mm sucking air out.
Thank you in advance.
