Ok so I bought a MSI GE62 Apache pro just a couple days ago and when I play games on high settings, I get temperatures mid 70's low 80's is this too much on the cpu? the GPU usually stays around 60 degrees..
Do you run a similar setup? I feel alot more confident when I heard your response...
i dont, however mobile core 4th gen i7 Tj max is 100c . start worrying if cpu temp climbs over 90c! as for the gpu 60c its just awesome! you can use a laptop pad or something to help temps remain as low as possible!
your temps are fine.such temps while gaming should be expected! i wouldnt worry! it is a laptop afterall, you cant just compare your temps with desktop cpu or gpu.!
good cooling solution for a laptop, as you can see.
