Question Is my CPU underperforming? Low CS:GO FPS (CPU-Z Scores)
Mar 20, 2019
Parts
CPU | i7 6700k
GPU | GTX 1060 3gb
RAM | 8gb G-Skill 2133mhz
MB | Asus B250F STRIX
CPU-Z Benchmark score - https://valid.x86.fr/z2vm63
I am getting lower than expected FPS on CS:GO for example, on max, I run at around 110-160fps depending, sometimes higher but not so much. When I drop it to low settings, it increases slightly.
Prime95 stress test peaks at around 85 degrees, but is average around 70 degrees.
Is there something else that could be causing such low fps?
