high is over 70°c
use msi afterburner to set a fan curve to make the fan work at 60 or 70%
your gpu will only fry over 80°c and it will shut down itself before that, the only problem is the noise and msi afterburner should help you
also reduce some settinga to very high or high, that gpu is not for those settings, surely you have weird fps, unstable framerates
