N Noodlesz Prominent May 8, 2017 6 0 510 Nov 5, 2017 #1 When I'm playing games my gpu jumps up to 42c-52c and it's just csgo or warframe. Is this normal ? When I play league it's about 32-37c. Am I freaking out or should this be normal where as my cpu it's around 80-96f
Solution G G Greg Gregorich Nov 5, 2017 52C is 125 Fahrenheits for gpu its a lot 80-96 Fahrenheits normal temp under the load are cpu 50~60 F gpu 60~65 F air cooling
pellemans101 Prominent Nov 5, 2017 56 0 640 Nov 5, 2017 #2 Did you overclock any components. The Temperatures vary for different CPU / GPU's Upvote 0 Downvote
G Greg Gregorich Distinguished Feb 13, 2014 891 0 19,060 Nov 5, 2017 Solution #3 52C is 125 Fahrenheits for gpu its a lot 80-96 Fahrenheits normal temp under the load are cpu 50~60 F gpu 60~65 F air cooling Upvote -1 Downvote Solution
J jaslion Splendid Dec 17, 2012 6,424 0 22,160 Nov 5, 2017 #4 Greg Gregorich : 52C is 125 Fahrenheits for gpu its a lot 80-96 Fahrenheits normal temp under the load are cpu 50~60 F gpu 60~65 F air cooling 52c is fine for a gpu. Upvote 0 Downvote
G Greg Gregorich Distinguished Feb 13, 2014 891 0 19,060 Nov 5, 2017 #5 jaslion : Greg Gregorich : 52C is 125 Fahrenheits for gpu its a lot 80-96 Fahrenheits normal temp under the load are cpu 50~60 F gpu 60~65 F air cooling 52c is fine for a gpu. good luck sir! Upvote 0 Downvote
