Is My GPU temperature and power safe?
Joelsome2211
Commendable
May 24, 2016
9
I have an AMD R7 200 series graphics card over clocked to 1000 clockspeed on both the dials. What should I increase the power to? Also, the temperature never goes above 60 Degrees Celsius. Is my GPU safe?
I'm unsure as to what you should change your power setting too. Increase it slowly, .1 increments. Yes 60 degrees is perfectly safe. You're safe up to about 78C after that, I would start to get a little concerned about pushing it anymore. You can cause damage between 80C and 90C.
Thank you. I have fully upped the Power and it still only maxes 60. Is there anything else I can do to improve the performance of my gpu? I use it mostly for gaming.
