Is my GPU too hot under load?
Pokefinch27
81
How hot should my ASUS 7770GHz Edition get when its under load? Currently its at 68*C which seems like a lot compared to my CPU which is only at 21*C. (AMD Fx-4300)
Thanks for the help.
Hello,
68*C is completely normal operating speed under load.
If the card exceeds over 85*C when gaming, then it starts to get worrying.
You're fine^^
Hope this helps.
Hello,
You're fine^^
Hope this helps.
Yeah thanks, it normally only gets this hot when I'm mining bitcoins which is what I'm doing now 😛
