Hello everyone. I am in the process of building a gaming pc, and I have decided on all of the parts, but am having trouble with the graphics card. I am really struggling with finding a graphics card which I am able to harness all of its power without it being wasted by using a monitor that isn't good enough. I am looking at a Gigabyte Radeon R9 290 4GB Graphics Card.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125500&cm_re=gigabyte_r9_290-_-14-125-500-_-Product
I already have an ASUS VG248QE Monitor. It has a 144Hz refresh rate, and a 1ms response time at 1920X1080p.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236313&cm_re=asus_vg248qe-_-24-236-313-_-Product
I am worried that I will pay too much for the graphics card by using it on a monitor that will not be able to support the graphics card's full potential. Mostly concerned about frame rate. It seems that if I had a 60Hz Refresh rate monitor, I definitely would be over-paying, right? But I am still not sure if 144Hz is good enough.
Basically I would like to know where the 'sweet spot' is in terms of the the best possible graphics card for this monitor. I don't want to buy a 780 Ti if that means that a ton of potential is wasted on a monitor that isn't good enough. But I also don't want to buy a graphics card that is able to have its full power shown on the monitor, when there is room for an even better graphics card. I hope I am making sense. I need a graphics card that will put out maximum frame rate possible on ASUS VG248QE. But I have no idea what card will do that.
From what I have read, it seems that to have maximum performance of your graphics card, you must have a monitor that is capable of showing that maximum performance, or else there is wasted potential. Low quality monitor + High quality graphics card = Money wasted on graphics card, right?
PC will be used for primarily gaming (hopefully ultra settings), with internet browsing, and typical everyday stuff. No video editing or rendering. Any help would be greatly appreciated. I'm really stuck. Thanks!
-Justin
Other specs:
i5-4670k @ 3.4GHz 4 core
MSI Z97-GD65 Motherboard
Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Seagate Barracuda 1TB 3.5" 7200RPM HDD
Corsair CX 600W Power Supply
Seagate 600 Series 240GB SSD
212 EVO CPU Cooler
Apevia X-CRUISER3-BLUE ATX Mid Tower Case
-Justin
Other specs:
212 EVO CPU Cooler
