Ok so let me describe my problem:
So I was playing games on my gtx 970 (all specs at the bottom) for past 2 years. Everything was working jsut fine, fps were stable,temps were ok,fans were quiet and i had no artifacts at all.
Then one day (reasons doesnt matter) i gently pulled out my GTX 970 and one (4gb) ram module out of my pc, then switched settings in BIOS to integrated settings and was using my pc as usuall (wasnt playing any games - was only coding,watching movies etc) just fine.
In the mean time my card and memory module was lying in the box in my room.
After 2 weeks of break i finally put my card back where it belongs and...and I found out that the card is not working anymore..kinda.Listen carefully now.
So first thing I did was conencting my RAM and then GPU (PCI 1 slot,power supply conencted) and then connected it with my monitor with HDMI cable (cable is working because thats how my monitor was connected to my integrated card for past 2 weeks).I powered on my PC only too see that resolution was extremly low (800x600) and i had white/blue stripes all over my screen (shown on ss - not mine ss but mine artifacts looks the same).Whats funny is that the artifacts were not only in windows but in bios/everywhere else too.
https://www.overclock.net/content/type/61/id/2882664/width/500/height/1000/flags/LL
After couple of minutes I realised the following things:
1.I couldnt change the resolution
2.Fans were spinning
3.Radiator/GPU was not heating/getting any warmer
4.Card was detected as Microsoft Basic Video adapter (sth like that).
5.In GPU Z i could see nothing (gonna add ss soon)
What i tried:
1.Uninstalling Drrivers with device manager/ddu etc.
2.Reseting BIOS settings to default (both using settings and pulling out the battery)
3.Cleaning ports.
4.Removing/replacing RAM modules.
5.Checking if everything was connected/powered.]
6.Forcing driver installation - one time it helped and i could see my card as GTX 970 in device manager but nothing else has changed.
What I havn't tried yet (because i cant)
1.DVI port - no cable/adapter.
2.Different PCI slot since my mobo has only one
3.Different PC (only laptops arround).
4.Baking it in the oven.
So in short:I boot my pc,i have low res,artifacts even in bios,fans working,gpu not heating,stats/nvidia drivers are being detected,sometimes i cant even start windows (only safe mode) after i tried to install drivers.And i don't see any damage/scratches on my GPU.
Here are the specs:
1GPU - Nvidia GFORCE 970 Gigabyte Windforce 4GB
2.8 GB ram hyper x (2 cubes x 4)
3.I5 6500 Skylake
4.PSUCorsair CX600M
If you need more info tell me i will give you everything.I dont know what to do anymore and what might be the cause.
What i tried:
3.Cleaning ports.
Here are the specs:
3.I5 6500 Skylake
4.PSUCorsair CX600M
