[SOLVED] Is my HP LE1901w monitor compatible with Radeon R7 370 using a passive dvi to vga adapter
Riley97
22
Is my HP LE1901w monitor compatible with Radeon R7 370 using a passive dvi to vga adapter. Or do i need an active adapter?
It depends on the specific card. But IF the DVI port has ports for four pins around the wide blade connector it is a DVI-I port and will work with a passive adapter.
It worked nicely the first time I plugged it in, but now the monitor no longer detects anything from the pc.
So it this your actual question, you don't have a display? Test the monitor with another system or test the video card with another monitor to see where the issue may be.
I would replace that monitor, you have a pretty decent video card, it's silly to have it connected to a low spec small monitor. You can find a newer 1080 screen for cheap used with the correct connections for your video card easily.
