Is my memory running at the correct speed?
Ferrariassassin
1,514
7
19,795
And here is the memory i have installed.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Based on what I see, you should be running with cas latency at 9 but it shows 11; you must turn on your xmp profile in the bios and update to see if you can get the better timings to show. Your speed is fine but you have "loose" timings for what you paid for.
How do i do that? And the Speed and voltage are good i just need to change it to 9-9-9-24?
go into your bios and look for xmp. It should look something like this:
http://media.bestofmicro.com/I/H/345401/original/asus_p8z77-v-lx_1.png
That's for an Asus motherboard but if your's isn't there should still be something similar
XMP is an auto setting to get what you paid for so you don't manually have to adjust the timings, voltages, etc. Your ram as paid for is rated to run at 1600MHz cas 9 at 1.5v so simply changing the default to the xmp profile should fix that for you.
Thanks man ill do that! :) Do i set it for both of my sticks or does it count as both?
Only one set of timings can be configured. As long as both of your sticks are identical, it should work just fine.
