Is my monitor bleeding?
"Its a bit annoying."
that is all the reason I would need to RMA it. seriously it will either get more annoying, or you will get used to it, if it is brand new it is not meeting your expectations as proven by "Its a bit annoying." I would RMA it while you can, during the RMA process go out and look at a couple monitors, if your able. I would assume the entire range does that, I would look for a different monitor.
this is why I will never buy a monitor or tv without looking at it in person.
TN panels really sucks , now i noticed that i am getting low visibility on the top of the monitor and better on the bottom , if i drag a blue/red or whhatever colour icon on the top it becomes stronger/darker while in the middle is as it should and on the bottom washed out , thats worse..... Didnt have a choice , i wanted a 144hz monitor for my gaming at about 300 so no ips and lg had the best color and performance quality. Gaming is a dream with this one the movement in fps games , the input lag i can strongly feel the difference i wont go 60hz/fps never again! but my 150 euro lps samsung had superior viewing angles and a bit better colour. I didnt expect having colour changing due to viewing angles when my eyes looks directly in the middle of the screen. i feel half happy half sad.
Is the colour difference normal?
