[SOLVED] Is my monitor dead?
Hi,so in my setup i have 2 monitors,main is BenQ 2400WA, the second one is https://www.asus.com/us/supportonly/VH192D/HelpDesk/ .
Yesterday my friend came over for New Year's and we played mortal kombat x and fifa.While we were playing i could hear a buzzing sound coming from the second monitor (asus),i kept unplugging the power cable and replugging it hoping it it would fix it,but it didnt so i just couldnt bother with it anymore and left it as it was.Today when i turned on my pc everything was fine,until i was playing a match of csgo and my second monitor (asus) was constantly changing its brightness a little bit every second.When i went to monitor menu the brightness was set to 90 as always,but you could see the brightness changing.Then the sound from yesterday came back,and then boom,black screen.I know the problem is not my GPU since i always keep an eye on my temps,and the main monitor was and still is working perfectly,so it is not my system.I then pressed the monitor power button to shut the monitor off,then i turned it on to see my screen was still changing brightness,and the screen was a little bit purple-ish,and after 10 seconds black screen happened.I did that a few times and nothing changed.I googled what could be the problem before posting here and i read that it might've been overheating.Im not gonna lie i use my system 10 hours+ when im home so overheating could be the problem.
Thoughts?
Oh yeah and i checked my cables,all of them work on the main display so the cables are not the problem.
What a great start to 2021 :)
I would try and bother with fixing it but it would cost more than the monitor so its a no go/
It had a good run, always there when i needed it the most.All those spotify playlists and youtube videos,while i was waiting in queue for csgo.And it died on duty.
