Question Is my monitor dead?
floorcleaner
54
Is my monitor dead? I've been using this monitor without any problems for the past four years. However, when playing a game today, all of a sudden the brightness raised on its own, and the screen began flickering with shadows under the texts and a black transparent line on the top of the screen.
View: https://www.youtube.com/watch?v=Gg7QdwRSOU4
My PC specs
Monitor: BenQ EW277HDR
CPU: i5 10400f
Motherboard: MSI H410M Pro-VH
Ram: Crucial 2 x 8GB DDDR4 2666
SSD/HDD: 1 x Crucial MX 500 sata, 1x WD 570 1tb Nvme/1x Toshiba 7200 rpm 2TB.
GPU:GIGABYTE GAMING GeForce RTX 3060 Ti
CPU COOLER: GAMMAXX 400 V2 BLUE.
CASE: XPG STARKER AIR
OS: Windows 10 Pro,Version 22H2.
PSU: XPG Core Reactor 750 watts
Try connecting the display to another device to see if the issue occurs again.
Also, make sure connections are firmly attached or even swapping cables.
floorcleaner
54
Budget? Any technical preferences? Or, just another of what you have now?
BTW, have you tried turning off the sensor to see if it makes a difference?
It has gotten worse now.
1080p or 1440p with 60 Hz is ok. Also, I only play single player and co op games, so any decent monitor is fine for me.
Budget is under 20000 indian rupees.
Any brand other than Benq
This one ok? https://www.amazon.in/LG-IPS-sRGB-H...246-4867-a18c-fb81dfb899c2&pd_rd_i=B0BRQT57RC
COLGeek
Cybernaut
Try this on for size...
floorcleaner
54
I think they are selling old stock. The model year is 2017.
COLGeek
Cybernaut
Could be. There are lots of choices there aside from the one previously recommended. Have you seen anything of interest?
I prefer Samsung displays/monitors. For example:
floorcleaner
54
Hey, what do you think about this monitor? https://www.amazon.in/LG-UltraWide-...1687672190&sprefix=lg+mo,aps,227&sr=8-10&th=1
