A Augustaronio Reputable Dec 31, 2014 7 0 4,510 Jan 1, 2015 #1 Is a ipiel-la3 (eureka3) from an hp is it compatible with a Asus radeon 7770 graphics card when I plug it in the green light is on in the card but my case doesn't light up and there's no display but everything is spinning and everything's on
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Jan 1, 2015 #2 Your mobo has a PCI-E card so that's good, do you have the PCI power cable plugged into the GPU (the 7770), and is the PSU at least 500 or better? Upvote 0 Downvote
A Augustaronio Reputable Dec 31, 2014 7 0 4,510 Jan 1, 2015 #3 No its a antec 450 with a 6pin is there anyway to keep my psu or is that the problem is there anyway to get the voltage to work idk help Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Jan 1, 2015 #4 I'd want a stronger PSU, know of anyone you could borrow one from - just to test and see with Upvote 0 Downvote
A Augustaronio Reputable Dec 31, 2014 7 0 4,510 Jan 1, 2015 #5 Is there anyway to boost the voltage or power on it because it should still power it correct? Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Jan 1, 2015 #6 Might or might not, if marginal it could surge and damage the card or itself or other components Upvote 0 Downvote
