Is my motherboard Compatible with GTX 1080 Ti and i7-770 CPU
MERGED QUESTION
Question from redhot3 : "Is my motherboard Compatible with GTX 1080 Ti and i7-770 CPU"
I don't think it supports the 7700....at least it's not listed here.
http://www.cpu-upgrade.com/mb-ASUS/H87-PLUS.html
The fastest i7 looks to be the 4790K.....but it will support a GTX 1080 Ti.
I see. They do seem good. Though, I was considering Z87 pro gamer or ASUS ROG Maximus IX Extreme.
The thing is I made a small mistake. I purchased the i7-7700 yesterday and I'm waiting for it to be delivered, without knowing if it will be compatible with my motherboard. Although, I do not mind buying another motherboard.
I need to make sure if I have the DDR4 ram or not, I'm not at home atm. But I guess, since I have already purchased the GTX 1080 ti and i7-7700, I guess I should just go with the motherboard. No? Which Z370 / Z270 motherboard do you recommend?
You don't have DDR4 RAM if you plan to reuse what's in your H87 board, H87 only supports DDR3.
I would personally return the 7700 if you can. If you cant then really any H270 or Z270 board would be fine for a locked i7 7700. Something like that maximus is a waste of money with a locked CPU however. I would look at the ASUS H270 or Z270 prime.
I see. Hm.
What DDR4 would you recommend? Which is the best?
- CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) 288-Pin DDR4 DRAM DDR4 3000 (PC4 24000) Desktop Memory Model
- G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Memory (Desktop Memory) Model F4-3000C16D-16GTZR
- Team T-Force DARK 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Memory (Desktop Memory) Model TDRED416G3000HC16CDC01
- G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Intel Z170 Platform / Intel X99 Platform Desktop Memory Model F4-2400C15D-16GVR
- 16GB DDR4-3600MHZ CL17 KINGSTON XMP HYPERX PREDATOR, 2X8GB
