That mobo has no header for either of the common RGB lighting systems. If you get lighted parts you will also need a Controller of the correct type to power and control the lights.
There are two very different and incompatible RGB systems dominating now, so be sure to get all your parts for the SAME system. The simpler one is called just plain RGB, and it uses a 4-pin connector that supplies 12 VDC power to the lights, and other Ground control lines. The more complex is the Addressable RGB (or ADDR RGB or ARGB) that uses a 3-pin connector (looks a lot like the 4-pin one, but with one pin missing) and supplies its lights with 5 VDC power and a digital control line. Short-form labels often are 4-pin 12 Volt, and 3-pin 5 Volt.
Do not...
