L Luxirigex Reputable Jun 11, 2014 5 0 4,510 Jun 11, 2014 #1 I currently have a MSI g41m-p23 motherboard installed and I am planning to upgrade my graphics card to a Diamond 4870PE51GDI ATI Radeon HD 4870 GDDR5 1GB PCI-E Dual DVI. Is the graphics card going to be suitable?
Dunlop0078 Titan Ambassador Feb 13, 2014 13,300 146 70,990 Jun 11, 2014 Solution #2 Yes that motherboard will work fine. Upvote 0 Downvote Solution
L Luxirigex Reputable Jun 11, 2014 5 0 4,510 Jun 11, 2014 #3 Dunlop0078 : Yes that motherboard will work fine. Thank you so much for the quick reply! 😀 Upvote 0 Downvote
Dunlop0078 Titan Ambassador Feb 13, 2014 13,300 146 70,990 Jun 11, 2014 #4 Luxirigex : Dunlop0078 : Yes that motherboard will work fine. Thank you so much for the quick reply! 😀 No problem. Upvote 0 Downvote
