is my Motherboard is compatible with the R7 370 plz help
It will work. You can install anything up to a GTX 980 Ti as long as your PSU can take it.
Your stock PSU likely will only be able to handle a R7 370 however.
I do not think your PSU will be able to hold the upgrade to a GTX 950. But it will depend on the PSU.
thx dude for your reply i will upgrade my psu to 500 w
thx man for your reply ok i will get gtx 950 :)
