My computer has been acting very strange for the past few days and I would like to know what's actually going on.
Specs:
mobo: Gigabyte 970A-DS3P FX
CPU: AMD FX 8350
GPU: GTX 1050ti and a GT 710 for second monitor
PSU: Corsair VS 600
16GB DDR3 ram
WD Blue 1TB hard drive
I've had this setup for almost exactly 2 years now, and the only problem I've had was when I first built it it wouldn't post for an hour, and then it did and never gave me problems.
What's been happening started three days ago, when I was playing For Honor, my computer suddenly turned off and restarted (no warning.) For the rest of the day, it would restart from 5-60 minutes after I turned it on. I figured I should reset windows, so I did a hard reset, in which the computer shut off mid wipe of the hard drive and, while it and all its components would turn on, it would not post. I posted a question to the Windows 10 board, where it was recommended I take out my wifi adapter card, and I did, and the problems was solved. I finished the wipe and redownloaded all my stuff through Ethernet, and the next day downloaded some games with no problems. Today I was playing Stalker shadow of Chernobyl, a significantly older game that was a breeze for my PC, and it suddenly crashed and restarted with no warning again. It only did this again once after rebooting it and now it's back to not posting at all. I have tried several things to see what was causing the issue:
Took out each gpu and tested them individually
Took out both gpus (in hindsight this was kind of a dumb test but I'm rather computer illiterate)
Put the wifi adapter card back in (when it didn't work, I took it out again)
Changed ram slots and tested each ram
Changed the power slots (on the mobo) my system fans were in
Checked my cpu for damage and applied new thermal paste
None of these solved the issue, so I'm thinking it's possibly the motherboard, but I'm broke and can't afford a new one so I'd rather be sure than spend the money now. I'm confused because the issue seemed to solve itself two days ago but now it's broken again. Help would be appreciated.
Specs:
CPU: AMD FX 8350
PSU: Corsair VS 600
16GB DDR3 ram
