Hi,
I just received my GPU (XFX 5700XT ThiccIII) from the XFX support because it had a problem with one of the fans.
After re-installing it, I now can't turn on the PC and I have the "no signal" message.
I tried the screen on another PC, and it works fine.
I also realized that the PCI-E slot is a little bit damaged.
So my question is: could the problem come from the PCI slot? Before I sent it to the support, the PC was correctly starting...
Or is this the graphic card ? as it just comes back from the support, it would be suprising
https://www.casimages.com/i/210124081556768569.jpg
Thanks a lot for your help
