Is my parts bottleneck ?
enyceckk101
59
I got A-data 800mhz
and I got an Q9300 CPU from intel and want to OVERCLOCK to 3.6ghz or 3.7ghz with aftermarket cooler
I try to oc it , but the max I can go is 3.2ghz 426 x 7.5 FSB 1.35v , memory @ 1023mhz 2:1 ratio 5-5-5-15 timing 2.1v ( default is 800mhz )
I got asus p5e motherboard
should I get better ram for overclock ?
I was planning to get
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227347
^ 1200mhz
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
^ 1066mhz
which 1 should I buy ?
Thanks
CK
Priv
135
Before you go off and buy memory first wonder if it's worth buying memory? In real life applications there is no difference between 1066 C5 and 800 C4. Also are you sure your memory cant go higher? My DDR2-800 modules wouldnt go above DDR2-1030 C5, but as soon as I set DRAM CLK SKEW to advance 150ps I can happily run DDR2-1200 6-5-6-15.
enyceckk101
59
I tried alot of setup and tweaks , I still can't get my ram any higher than 1066 without auto reboot
i want 1200mhz or 1066mhz so i can overclock my cpu ( if memory really bottleneck my cpu )
1066mhz and 1200mhz is almost the same price ( with rebate )
