Question Is my parts list any good?
https://pcpartpicker.com/list/HDRfDx
I already have a cooler master heatsink for my cpu, a 500 gb ssd, and two extra fans from a previous build.
My 2 cents, your build is fine and capable if you choose to keep it. I made some changes based on slight performance and personal preference. I’ll start with the power supply, I changed to the Seasonic as I think they are the best and it saved you $5. Changed your hard drive to a NVME drive that’s cheaper and has much faster capability. RAM for Ryzen 3 needs to be 3600 to get the best performance so it upped the price a bit and then I evened it back out with the motherboard. The x470 will need a bios update to run a ryzen 3600. The b450 max from MSI is ready without a bios update and is plenty capable for a ryzen 3600.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Newegg)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: G.Skill Trident Z Neo 16 GB (2 x 8 GB) DDR4-3600 Memory ($119.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($109.99 @ B&H)
Video Card: EVGA GeForce RTX 2060 SUPER 8 GB XC ULTRA GAMING Video Card ($443.98 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case ($97.98 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.98 @ Newegg)
Total: $1161.90
Generated by PCPartPicker 2020-03-30 02:02 EDT-0400
Mar 19, 2020
15
Total: $1161.90
Are there any other boards that have more 3.0 usbs and possibly a better aesthetic without a bios update at the same price range of the tomahawk?
Cheapest without a bios update would be
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard ($133.99 @ Newegg)
Total: $133.99
Generated by PCPartPicker 2020-03-30 03:47 EDT-0400
Next option up in price:
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard ($144.99 @ Newegg)
Total: $144.99
Generated by PCPartPicker 2020-03-30 03:50 EDT-0400
Total: $133.99
Total: $144.99
If you can stretch the budget, this one will handle and Ryzen 3000 and 4000 when they come out and last you for a good while.
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard ($199.00 @ B&H)
Total: $199.00
Generated by PCPartPicker 2020-03-30 03:52 EDT-0400
Mar 19, 2020
15
Total: $199.00
Thank you for all your help, I’m brand new to building so this is a lot of help. I really debated on the gigabyte x570 but I think the tomahawk overall would be a better purchase. Would the gigabyte actually be worth the extra 90+ dollars?
Only if you think you’ll want to replace the cpu in the next couple years with a high end 3000 or 4000 series
