Is my pc better than a ps3/ps4
Agentrai
Here's my pc specs:
CPU: AMD A8-7600 Accelerate Processor
Ram: 8GB DDR3 System Memory
Storage: 2TB Hard Drive
GPU: Amd Radeon R7 Graphics
Monitor: 1920 x 1080 60Hz
I need to know if my pc can play Assassins creed Black flag or Unity with higher FPS and resolutions than a ps3 and ps4.
If my pc can't run Assassins Creed Unity or is outperformed by the ps4 or the Xbox1 can you recommend any necessary upgrades.
Thanks
p.s I really need to now if my pc can run Assassins Creed Unity so I can decide whether to pre-order it.
The PS3 runs most games at either 600p or 720p, at 30 fps, low settings. Yes, your APU is capable of matching that or beating it.
The PS4 runs games at 900p or 1080p, 30-60 fps, high settings. No, your APU is not even close to that.
As others have said, it would take a GTX 750 Ti or R9 270 to beat a PS4 and ensure matching settings or higher settings in AC Unity.
instead of apu can u afford fx 6300 or 8320 a ps4/xb1 uses a 8 core amd jaguar proceser jaguar is custom made so if u go with fx series it would be much greater than ps4 /xb1
and which r7 are u purchasing give us a model number
