Is my power supply compatible?
NotHimAgain
37
ok so i want to upgrade my gear so i've decided on an r9 390x and a fx-9590 on an asus M5A99x Evo motherboard. However, i don't know if the psu i chose, wich is a Rosewill ARC-750 750 watt, is compatible. Can anyone help me?
Your choices for the 9000 series:
Asrock 970 Performance
ASRock 990FX Extreme9
ASRock 990FX Extreme6
Asus Crosshair V Formula-Z
Asus M5A99FX PRO R2.0
Asus Sabertooth 990FX R2.0
Gigabyte GA-990FXA-UD3 R4.0\5.0
Gigabyte GA-990FXA-UD5
Gigabyte GA-990FXA-UD7
MSI 990FXA-GD80V2
AMD.COM
Warning: This power draw of this CPU is almost twice that of the average CPU. Due to this, AMD recommends using at minimum a 850W to 1000W power supply. For cooling, AMD recommends using either either closed loop liquid cooling , h100i minimum or full system liquid cooling.
MSI 990FXA-GD80V2
AMD.COM
