Is my power supply enough for this system?
gproefficient
47
Hello, I have a new ACER ATC 705 pc, and I am switching out the PSU to install my psu (Inland 650w) from the other computer and to install my GPU. ( r9 270X)
I noticed that when I took the psu out of the acer pc, it showed a 3.3v of 20 and a 5v of 26.
It also showed a -12v of 0.8A
My inlandpsu is 3.3v 15A and 5v 15A
and -12v 0.3a.
Does this mean I need to get a new psu? the inland psu was powering an older costume built pc
that was still using lga775. But this newer pc is different and I'm not sure if I can use this psu, or if its even enough
Its not on the radar as being good. i don't even see it being bronze rated.
plug in your computer parts and it will give you the wattage estimation. add 20% then get that wattage+....
https://pcpartpicker.com/parts/partlist/
cheapest tier 1
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($59.99 @ NCIX US)
Total: $59.99
Generated by PCPartPicker 2015-07-22 15:00 EDT-0400
but i did not check your wattage rating.
cheapest tier 1
Total: $59.99
