Is my PSU going to be enough?
NikkiDennis6
28
Well hello there!
Brand new into PC building here,and i just bought my parts to build my PC 😀
As i spoke to a few people about my specs,alot of people said that
my power supply wont be enough for gaming as i was intending to use my PC for it in the first place.
I'd love if you could take a look at the parts i got and if you could please give me any tips of what i should do.
CPU: Intel Pentium G3258 (probably OC'ing it to 4.2GHz)
GPU: Sapphire Radeon R7 370 Nitro 2Gb
RAM: 8Gb Crucial Ballistix Sport 1600Mhz
MOBO: Gigabyte B85M-HD3 R4
HDD: Toshiba 1Tb
SSD: Kingston V300 120Gb
PSU: be quiet! Pure Power L8 400W
Case: Cooler Master K280
Your PSU will give you 360 watts on the +12volt rail / 30 amps. Your power use for the 370 is about 150 watts and the G3258 is 53 watts at stock clocks plus the rest of the system uses some power too. You should be maxing at around 250 watts with overclocking pushing it a bit higher. It's not ideal but it should work ok. If you have random shutdowns you'll have to get a larger PSU.
RMA the PSU. I may work, but you are pushing it.
