I have a few questions about my build and about the Power Supply. Keep in mind that I'm new to building computers.
Build - http://pcpartpicker.com/p/GZHnBm
Questions:
1: The title of this thread.
2:Can I even install the GPU? I heard somewhere that the GTX 980 TI uses 6x8 pin connectors and according to pcpartpicker my PSU only has 4 6x2 connectors or something along the lines of that. Can I still install the GPU?
3: What is considered a safe/good/whatever leftover wattage? For example: if my computer is using up 300W and it's running a 400W Power Supply, is that ok? Is there a standard to how much wattage leftover that is considered to be good? I know when overclocking you sometimes need to increase the voltage, would that mean upgrading?
4:If I ever needed to SLI two of these in the future, let's say for 4K, would I need to upgrade my PSU?
5: I might OC my CPU/GPU. Should I possibly consider a new PSU or will this one suffice?
Any response is taken into consideration.
Questions:
