Is my Radeon 9800 Pro responsible for system temp increase?
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I just replaced my 9600 Pro with a 9800 Pro and my system temps seem to
have gone up 4-5 degrees. Query: is this because a.) the 9800 puts out
more heat so the temps rise, b.) when I put the card in I jumbled up the
cables inside the case screwing up the air flow, c.) a combination of
the two?
"You keep using that word. I do not think it means what you think it means."
Inigo Montoya
Steve [Inglo]
G
Guest
Guest
> the two?
I guess that would depend on whether or not you interrupted the airflow with
the cable adjustments.
Probably a combination of both.
What ARE your system temps? And what are your room temps?
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
G
Guest
Guest
On 6/29/2004 11:59 AM Ben Pope brightened our day with:
>>the two?
>Ben
Well everything's a little whacked now, I replaced the passive heatsink
on my northbridge with a Vantec Iceberq and replaced the arctic alumina
on my CPU HSF with arctic silver 5 (had been planning to do this for a
while, had the stuff lying around just waiting for the right impetus).
Tied up all the cables and made more effective use of them (dragging
another molex to the video card caused some problems).
This morning when the room was definitely cooler than it is now the NB
was at 44C and the CPU at 50C idle.
Right now (ambient probably 24C) after what I've done, the NB is at 38C
and the CPU is at 46C idle. And I guess the AS5 needs to "cure" a bit.
FYI, this is Barton 2500 overclocked to 3200 speeds on a nForce2
motherboard, and for whatever reason I've found that this MSI board
reads hotter than a lot of other nForce2 boards.
Now I'd say the last time I looked at the temps when my 9600 Pro was in
there the system was probably a little less than it is now with the
modifications I made this morning.
It appeared that there was a +5C change thanks to the 9800 Pro, wanted
to see if that was common or not.
The other thing is, I have one of those video card coolers that fits in
a PCI slot (which I've never thought was too effective), and I was
considering whether I should slap it in next to the 9800Pro. Good idea?
I try not to really obsess about temperatures as long as everything's
running stable, I don't give a f__k if I have the lowest temps around.
I won't be overjoyed, but my CPU idling at 46-48C doesn't bother me. So
once I get through monitoring stuff for the next few days I'll quit
watching the temps unless something goes wrong.
Inigo Montoya
Steve [Inglo]
G
Guest
Guest
I got exacly the same problem when I went up to a 9800 pro from a 9500 pro. The 9800 pro (and
prolly any card at the same level of performance) puts out a lot of heat, and this comes from the
bottom of the case rather than the top (where the processor and the psu fan is), as well as coming
from the bottom face of the card rather than the upper one. all this makes it difficult to get rid
of the hot air quickly using airflow, so by the time it is ejected, most of the hot air generated
has warmed your components up!
I had not much luck with adding extra fans (they work but they are just plain noisy) until I
replaced the stock 9800 pro heatsink with an arctic cooler, which has the advantage of venting the
heat out of the case at source, which solves the problem directly. not only did the gpu overclock
better, but the case temp went down.
HTH
S
> to have gone up 4-5 degrees. Query: is this because a.) the 9800
> puts out more heat so the temps rise, b.) when I put the card in I
> jumbled up the cables inside the case screwing up the air flow, c.)
> a combination of the two?
G
Guest
Guest
Case temp?
Change in what?
Maybe, depending on the answer to the questions.
If your Diode temp is peaking at <50°C, no need tro worry at all. >60°C is
where I start thinking about more cooling. >70°C is where I start
underclocking things (or not overclocking them).
Ben
