Hello,im new to the scene as for building a gaming PC,i had a small budgjet and the spend came to about £400 the stats are as follows.
Coolermaster CM690 II Lite with Coolermaster GX 650W PSU
XFX HD 6870 1GB GDDR5
G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX
Asus M4A78LT-M Socket AM3 MOBO
AMD Phenom II X4 955 Black Edition C3
I feel my computer isn't running as it should,sometimes its smooth the next it stutters,i have taken some pictures of my cpu-z settings to see if anyone can spot some big factors in my computers behaviour.
http://valid.canardpc.com/show_oc.php?id=1940807
Memory Kit CL9 (9-9-9-24),that is what my ram is suppose to be set too,i have the voltage set to 1.5v,but as you can see in the link i gave,the setting are way up,is that normal or do i need to reduce it down to what its ment to be set at?
